08-08-2014
01:18 AM
- last edited on
06-04-2019
09:44 AM
by
Paul Zimmerman
When i tried to connect to the LAB using the browser it hanged on downloading the client , so it asked to download and setup manually ,
After i set up the anyconnect client and entered the URL sent by the reservation, it fails with the flowing errors
08/08/2014 8:43:39 AM] Ready to connect.
[08/08/2014 11:11:01 AM] Contacting https://64.103.37.21/rave04.
[08/08/2014 11:11:34 AM] Connection attempt has failed.
[08/08/2014 11:11:34 AM] Unable to contact 64.103.37.21.
[08/08/2014 11:11:40 AM] Contacting https://64.103.37.21/rave04.
[08/08/2014 11:11:59 AM] Connection attempt has failed.
[08/08/2014 11:11:59 AM] Unable to contact 64.103.37.21.
Although i can ping it form the PC
C:\Users\XXXXXXX>ping 64.103.37.21
Pinging 64.103.37.21 with 32 bytes of data:
Reply from 64.103.37.21: bytes=32 time=109ms TTL=237
Reply from 64.103.37.21: bytes=32 time=117ms TTL=237
Reply from 64.103.37.21: bytes=32 time=110ms TTL=237
Anny Idea ????
08-08-2014 01:45 AM
Sometimes it complete to ask the username and password but it never complete
[08/08/2014 11:38:59 AM] Contacting 64.103.37.21/rave04.
[08/08/2014 11:39:13 AM] Please enter your username and password.
[08/08/2014 11:39:49 AM] User credentials entered.
[08/08/2014 11:39:50 AM] Establishing VPN session...
[08/08/2014 11:40:31 AM] Connection attempt has failed.
[08/08/2014 11:41:23 AM] Contacting 64.103.37.21/rave04.
[08/08/2014 11:41:37 AM] Please enter your username and password.
[08/08/2014 11:41:52 AM] User credentials entered.
[08/08/2014 11:41:53 AM] Establishing VPN session...
[08/08/2014 11:42:32 AM] Connection attempt has failed.
08-08-2014 05:12 AM
We have verified connectivity to that VLAN this morning and could not see and issue. Can you try connecting again?
Joe
08-08-2014 05:29 AM
Now it connects and disconnects after 20 sec with an error
08/08/2014 3:23:28 PM] Ready to connect.
[08/08/2014 3:23:29 PM] Contacting 64.103.37.21/rave04.
[08/08/2014 3:23:31 PM] Please enter your username and password.
[08/08/2014 3:23:35 PM] User credentials entered.
[08/08/2014 3:23:37 PM] Please enter your username and password.
[08/08/2014 3:23:40 PM] User credentials entered.
[08/08/2014 3:23:42 PM] Please enter your username and password.
[08/08/2014 3:23:50 PM] User credentials entered.
[08/08/2014 3:23:50 PM] Establishing VPN session...
[08/08/2014 3:23:53 PM] Checking for profile updates...
[08/08/2014 3:23:53 PM] Checking for product updates...
[08/08/2014 3:23:55 PM] Checking for customization updates...
[08/08/2014 3:23:55 PM] Performing any required updates...
[08/08/2014 3:24:03 PM] Establishing VPN session...
[08/08/2014 3:24:03 PM] Establishing VPN - Initiating connection...
[08/08/2014 3:24:04 PM] Establishing VPN - Examining system...
[08/08/2014 3:24:04 PM] Establishing VPN - Activating VPN adapter...
[08/08/2014 3:24:36 PM] Establishing VPN - Configuring system...
[08/08/2014 3:24:36 PM] Establishing VPN...
[08/08/2014 3:24:36 PM] Connected to 64.103.37.21.
[08/08/2014 3:25:16 PM] Reconnecting to 64.103.37.21...
[08/08/2014 3:25:17 PM] Disconnect in progress, please wait...
08-08-2014 05:43 AM
I have not seen that error message before. Can you tell me where are you connecting from i.e. corporate network, open ISP etc and what OS are you using?
Joe
08-08-2014 05:45 AM
I am connecting from corporate network .
08-08-2014 05:49 AM
Can you confirm that WebVPN VPN connections are allowed outbound from your corporate firewall or are there any restrictions in place? As a test, can you try connecting from an open ISP if one is available?
08-08-2014 05:50 AM
Ok , will try it from home , thanks for your help
08-08-2014 05:53 AM
Please come back and let us know the result of the connection from home.
If you are still having an issue, we can look into it directly.
Joe
08-08-2014 06:12 AM
It is working when I used my mobile data network .
04-29-2017 04:38 PM
my a win Zip page is stuck to my window 10 computter screen how can i delete it?
05-01-2017 06:13 AM
Hello Maria,
If you have a question about the DevNet Sandbox, could you please open a separate thread? Also please provide more information about your issue with the DevNet Sandbox so we can pinpoint your issue.
Thanks!
Jacob
