Unable to start Meraki small business and enterprise sandbox
AntiPasha
It tells that active environment limit is 0
5 Replies 5
@AntiPasha might be down or taken out the reservation pool for work/maintenance, would check back later.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
AntiPasha
No, it doesn't. I haven't seen any information that it's down or taken out for maintenance. Is there any estimation when it'll be available again? Thanks
@AntiPasha in some cases in the past sandboxes are taken out of reservation for unexpected issues and no notice is given, i see in this case the 'launch' button is greyed out which mean this is not available for reservation. The team work as fast as possible to put these back in use for the community. You can try and access Cisco dCloud as they have Meraki sandboxes which you can use.
Hope this helps.
AntiPasha
Ok, thank you, I wasn't aware of such option within dCloud, will try it
jokearns1
Hi @AntiPasha ,
We had to take the Meraki sandbox off line for a while for maintenance.
Its now back in the catalog and can be reserved.
Joe
