virl issue with Sandbox-Cert error?
Richard G.
Frequent Visitor
Frequent Visitor
I tried the following from my ubuntu vm and it failed/with the following error
I did a pip install of all virlutils etc. I also tried the same w/ the devbox in the sanbox and got the same error
any ideas?
I can get output from the virl sanbox like "virl search"  with no issue:
However I get the following
From my box
(01_venv) me@-VirtualBox:~$ virl up virlfiles/5_router_mesh
Pulling from virlfiles/5_router_mesh
Exception raised while running your command
Please re-run as 'virl --debug ...' and collect the output before opening an issue
HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /virlfiles/5_router_mesh/master/topology.virl
(Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate
(_ssl.c:1108)')))
Pulling from default
From the Sandbox
[developer@devbox ~]$virl up virlfiles/5_router_mesh
Please open an issue and provide this info:
HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /virlfiles/5_router_mesh/master/topology.virl (Caused by NewConn ectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x1bd9d10>: F ailed to establish a new connection: [Errno -3] Temporary failure in name resolu tion',))
Max retries exceeded with url: /default/master/topology.virl (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x144acd0>:
Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
carlocon
While trying to run the Open NX-OS with Nexus 9Kv lab I tried to execute virl up command to create the NX-OS boxes, instead I kept receiving this message over and over:
[developer@devbox learning_labs]$virl up
HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /default/master/topology.virl (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x304bd10>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
Seems like a problem in communication with the repository but not sure if this is temporal or something I can do to fix it
mirceanistor
Visitor
from virlutils readme:
CML_VERIFY_CERT - The path to a PEM-encoded certificate file to use to verify the CML controller VM's SSL certificate. If you do not wish to verify the certificate, set this to "False"
Example:
export CML_VERIFY_CERT=/etc/certs/ca_bundle.pem
as they mention, you can set CML_VERIFY_CERT=false, if you don't wish to verify certificate.
you can set that in your ~/.virlrc as well.
