xr9kv node in CML stuck on QUEUED state
msanghera6
This is an issue I'm noticing on the newer platform of CML. I have a CML Personal lab reserved.
Currently the IOS XRv 9000 node is the only node in the topology (its the only thing I dragged out into the topology), and the only node that should be taking up resources.
It doesn't boot up. I'm not able to open the console (the button is not click-able, likely because the node will not boot). The memory usage of the CML Personal reservation is sitting at 74% idle (with no nodes active).
Is this a known issue? Is there a fix on the way?
msanghera6
To exapand on my initial post, all other nodes boot just fine, its only the Xrv9k that doesn't boot
I’m not sure on the sbx version/xr version but have seen some threads like this https://learningnetwork.cisco.com/s/question/0D53i00000msQAwCAM/unable-to-start-ios-xrv-9000-node where they have said certain versions had issues booting or were greyed out.
Hope this helps
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
