cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Ayuda configurar VPN CISCO 2811
Configuré una vpn en un cisco 2811 pero cuando me conecto a la vpn pierdo la conexión a internet, no se como hacer para tener internet cuando me conecto con el vpn client.
Pongo la configuración por si me puedes ayudar muchas gracias:
Building configuration...
Current configuration : 1911 bytes
! Last configuration change at 02:00:40 UTC Fri Oct 25 2019
version 15.1
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login vpnprueba local
aaa authorization network vpnprueba local
aaa session-id common
dot11 syslog
ip source-route
ip cef
license udi pid CISCO2811 sn FCZ132270FX
username admin password 0 cisco
redundancy
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group vpnprueba
key ******
pool vpnpool
crypto ipsec transform-set set1 esp-3des esp-md5-hmac
crypto dynamic-map map1 10
set transform-set set1
reverse-route
crypto map ma1 10 ipsec-isakmp dynamic map1
crypto map map1 client authentication list vpnprueba
crypto map map1 isakmp authorization list vpnprueba
crypto map map1 client configuration address respond
crypto map map1 10 ipsec-isakmp dynamic map1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.0.40 255.255.0.0
duplex auto
speed auto
crypto map map1
interface ATM0/1/0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
ip local pool vpnpool 10.10.0.80 10.10.0.90
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.0.0
control-plane
line con 0
line aux 0
line vty 0 4
transport input all
scheduler allocate 20000 1000
end
3 RESPUESTAS 3
Hola,
Quieres hacer una VPN sitio a sitio o una VPN Remote Access anyconnect ?
Veo un mix de configuraciones.
Saluds
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hola Julio, muchas gracias por responder quiero configurar una VPN Remote Access anyconnect
