cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Abrir rango de puertos en Cisco 1800
ignaciobajo
Hola
Neceitba abrir un rango de puertos a una videoconferencia SIP desde la WAN a la LAN.
Los puertos que tengo que abrir son
1720                      TCP
3230-3248           TCP
3230-3305           UDP
5060                      TCP
5060                      UDP
5070                      TCP
Para ello he configurado en el router Cisco 1800
ip nat inside source static tcp 192.168.0.169 1720 interface FastEthernet4 1720
ip nat inside source static tcp 192.168.0.169 5060 interface FastEthernet4 5060
ip nat inside source static udp 192.168.0.169 5060 interface FastEthernet4 5060
ip nat inside source static tcp 192.168.0.169 5070 interface FastEthernet4 5070
access-list 110 permit tcp host 192.168.0.169 any range 3230 3248
access-list 110 permit udp host 192.168.0.169 any range 3230 3305
route-map RADVISION permit 10
match ip address 110
ip nat inside source static 192.168.0.169 85.85.85.85 route-map RADVISION extendable
Pero no funciona
Segun indica el fabricante
You can configure the TCP or UDP port range by setting the base port, which is the lower end
of the port range (if, for example, port 3230 is busy).
The SCOPIA XT Series uses dynamic TCP ports 3230-3248 for the following:
• H.225.0: An H.323 protocol that specifies the messages and procedures used by
gatekeepers to set up calls.
• Q.931:A telephony protocol used for establishing and terminating the connection in H.323
calls.
• H.245: A Control Protocol used for multimedia communication; enables transferring
information about the device capabilities, as well as opening/closing the logical channels
that carry media streams.
• SIP: A signaling protocol used for creating, modifying, or terminating multimedia
connections between two or more participants.
The SCOPIA XT Series uses dynamic UDP ports 3230-3248 for enabling real-time H.323 and SIP
media, including audio, video, and H.224/data (RTP), and media control (RTCP).
Estara bien configurado el router?
4 RESPUESTAS 4
Julio Carvajal
Hola Ignacio,
Como se determina a traves de internet el configurar un rango de puertos para realizar NAT no parece ser soportado pero a traves de internet he encontrado 2 formas de hacerlo.
Una de ellas es la que tu configuraste, la otra aparece en el siguiente sitio web:
http://ciscovoiceguru.com/1784/forwarding-rang/
Mira ese link, trata de implementarlo y probarlo. Debo de admitir que la configuracion en el router es la correcta.
Ahora no es soportado por ende puede que no funcione, mi recomendacion es crear un script para crear las lineas estaticas una por una.
Saludos
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Muchas gracias
La configruacion es correcta pero no funciona, probare la otra en cuanto pueda.
Gracias
Hola
he probado ambas configuraciones y no funciona
ALguna idea mas?
Un saludo
Hola Ignacio,
Entonces la ultima opcion seria crear un script con powershell para crear la cantidad de lineas staticas deseadas debido a que los 2 workarounds disponibles no funcionaron, es esto o crear las reglas estaticas una por una que de solo pensarlo es aburrido
Saludos.
Julio
Julio Carvajal
