cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Help with the ip nat pool command
hammadjghanghro
Can someone please explain to me the use of 'nopreservation' keyword in the 'ip nat pool' command?
1 RESPUESTA 1
bzendeja
Hi Hammad,
The "nopreservation" keyword enables all the IP addresses in the pool to be used for dynamic translation.
Comparisons with option turned on and off:
a) option on:
ip nat pool test 10.0.0.1 10.0.0.2 prefix-length 24 nopreservation
c1841-7#sh ip nat tr
Pro Inside global      Inside local       Outside local      Outside global
53  10.0.0.2:0     25.1.1.13:0        14.1.1.11:0        14.1.1.11:0
--- 10.0.0.2       25.1.1.13          ---                ---
53  10.0.0.1:0     25.1.1.14:0        14.1.1.11:0        14.1.1.11:0
--- 10.0.0.1       25.1.1.14          ---                ---
The above shows that the first nat pool address is available for nat translation.
Or:
udp 10.0.0.2:6300  25.1.1.13:6300     14.1.1.11:6300     14.1.1.11:6300
a) option off:
The above shows that the first nat pool address is not available for nat translation of packets with ip unknown protocols.
Please let me know if this information helps you.
Bernardo
