el 04-18-2022 07:26 AM
Hello good morning, the query I have is, I have a network with segment 80 (192.168.80.X) but between computers connected to that network, they cannot see each other, nor ping the gateway (192,168,80.1 ). Does anybody know what is it due to??
I have this access list configuration on my switch; will it be something like that? What should I add or remove?
Greetings, I hope you can help me.
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.60.0 0.0.0.255
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.33.0 0.0.0.255
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.31.0 0.0.0.255
access-list 100 deny ip 172.16.1.0 0.0.0.255 192.168.32.0 0.0.0.255
access-list 100 permit ip any any
access-list 101 permit ip 192.168.80.0 0.0.0.255 host 192.168.2.1
access-list 101 permit ip 192.168.80.0 0.0.0.255 host 192.168.3.10
access-list 101 permit ip 192.168.80.0 0.0.0.255 192.168.70.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.31.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.32.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.33.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.34.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.35.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.37.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.41.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.54.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.60.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.80.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 101 deny ip 192.168.80.0 0.0.0.255 100.100.100.0 0.0.0.255
access-list 101 permit ip any any
access-list 150 permit ip 192.168.60.0 0.0.0.255 host 192.168.2.1
access-list 150 permit ip 192.168.60.0 0.0.0.255 host 192.168.3.10
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.31.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.32.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.33.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.34.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.41.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.54.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.35.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.80.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.70.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 150 deny ip 192.168.60.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 150 permit ip any any
access-list 199 permit ip 172.16.1.0 0.0.0.255 any
el 04-18-2022 09:32 AM
Check disabling the windows firewall or turning off the antivirus.
regards
el 04-18-2022 12:56 PM
hello,ir is not the firewall, i have already tried this.
tnks.
04-18-2022 11:06 AM - editado 04-18-2022 11:06 AM
I don't known in which interface you have configured the access-list 101, but try removing this line and tell us if work it
regards
el 04-18-2022 12:58 PM
hummm ok, it could be that line, i have already allowed it, i will see at the end of the day if i can ping between computers, and i will write to you again..
tnks!!!!
regards!!
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
