cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
MP-BGP With VRF - troubleshooting
inteldarvid
hello team
Good day
Could you help me with the following query, I am configuring a topology, core, h10, B4 and R1. The H10 and B4 Device have a VRF called VRF-MONTAJE and the core is a reflector route of the topology, between the CORE and H10 and B4 there is an MPLS. I configured the ipv4 and vpnv4 families and I can advertise and receive the prefixes of the networks, and I can even receive the R1 with ospf pefixes that are injected into the VRF-MONTAJE. I have the routes in the routing table, but I can't ping the routes, I have no prefix list, no route-map, no ACL, nothing. My question is the following, is something missing at the routing level to reach the networks?
Notes I have networks configured with loopbacks
Thank you
I attach the topology and configurations
B-4#sh bgp vrf
B-4#sh ip bgp al su
B-4#sh ip bgp al summary
For address family: IPv4 Unicast
BGP router identifier 3.3.3.3, local AS number 22927
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
1.1.1.1 4 22927 10 6 1 0 0 00:03:39 0
For address family: VPNv4 Unicast
BGP table version is 13, main routing table version 13
6 network entries using 822 bytes of memory
6 path entries using 408 bytes of memory
4/3 BGP path/bestpath attribute entries using 496 bytes of memory
1 BGP rrinfo entries using 24 bytes of memory
2 BGP extended community entries using 64 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 1814 total bytes of memory
BGP activity 6/0 prefixes, 6/0 paths, scan interval 15 secs
1.1.1.1 4 22927 10 6 13 0 0 00:03:39 6
B-4#sh ip bgp al nei
B-4#sh ip bgp al neighbors 1.1.11.1
For address family: IPv6 Unicast
For address family: IPv4 Multicast
For address family: IPv6 Multicast
For address family: NSAP Unicast
B-4#sh ip bgp al neighbors 1.1.1.1 ro
B-4#sh ip bgp al neighbors 1.1.1.1 routes
Total number of prefixes 0
BGP table version is 13, local router ID is 3.3.3.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 22927:20 (default for vrf VRF-MONTAJE)
*>i5.5.5.5/32 2.2.2.2 2 100 0 ?
*>i172.16.31.0/28 1.1.1.1 0 100 0 ?
*>i172.16.36.0/28 2.2.2.2 0 100 0 ?
*>i172.16.36.17/32 2.2.2.2 2 100 0 ?
*>i172.16.36.33/32 2.2.2.2 2 100 0 ?
*>i172.16.37.0/28 2.2.2.2 0 100 0 ?
Total number of prefixes 6
B-4#sh ip ro
B-4#sh ip route vrf
B-4#sh ip route vrf VRF-MONTAJE PRO
B-4#sh ip route vrf VRF-MONTAJE BGP
5.0.0.0/32 is subnetted, 1 subnets
B 5.5.5.5 [200/2] via 2.2.2.2, 00:03:07
172.16.0.0/16 is variably subnetted, 5 subnets, 2 masks
B 172.16.36.17/32 [200/2] via 2.2.2.2, 00:03:07
B 172.16.36.0/28 [200/0] via 2.2.2.2, 00:03:07
B 172.16.37.0/28 [200/0] via 2.2.2.2, 00:03:07
B 172.16.31.0/28 [200/0] via 1.1.1.1, 00:03:07
B 172.16.36.33/32 [200/2] via 2.2.2.2, 00:03:07
B-4#PC
Translating "PC"
Translating "PC"
% Unknown command or computer name, or unable to find computer address
B-4#PC
B-4#ping vrf
B-4#ping vrf VRF VRF-MONTAJE 5.5.5.5
Translating "VRF-MONTAJE"
Translating "vrf"
% Invalid input detected at '^' marker.
B-4#ping vrf VRF-MONTAJE 5.5.5.5
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
B-4#ping vrf VRF-MONTAJE 172.16.31.1
Sending 5, 100-byte ICMP Echos to 172.16.31.1, timeout is 2 seconds:
B-4#ping vrf VRF-MONTAJE 172.16.36.33
Sending 5, 100-byte ICMP Echos to 172.16.36.33, timeout is 2 seconds:
B-4#
CORE#sh run
CORE#sh running-config
Building configuration...
Current configuration : 3272 bytes
version 12.4
hostname CORE
boot-start-marker
boot-end-marker
enable secret 5 $1$Wxip$JUrUe5kg82DBSy9olvlaT1
no aaa new-model
resource policy
ip subnet-zero
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
ip vrf VRF-BODY
rd 22927:30
route-target export 22927:3020
route-target import 22927:3010
ip vrf VRF-MGMT
rd 22927:10
route-target export 22927:1010
route-target import 22927:1010
ip vrf VRF-MONTAJE
rd 22927:20
route-target export 22927:2010
route-target import 22927:2020
route-target import 22927:2010
no ip domain lookup
ip domain name lab.com
ip ssh version 2
username cisco privilege 15 password 0 cisco
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip ospf 1 area 0
interface Loopback31
description TEST-VRF-MONTAJE
ip vrf forwarding VRF-MONTAJE
ip address 172.16.31.1 255.255.255.240
interface FastEthernet0/0
description Dtribuccion Montaje
ip address 172.16.24.109 255.255.255.252
ip ospf network point-to-point
ip ospf 1 area 0
duplex half
mpls label protocol ldp
mpls ip
interface FastEthernet1/0
description BODY Distribuccion
ip address 172.16.24.113 255.255.255.252
ip ospf 1 area 0
duplex half
mpls ip
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
passive-interface default
no passive-interface FastEthernet0/0
no passive-interface FastEthernet1/0
no passive-interface Loopback0
router bgp 22927
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 22927
neighbor 2.2.2.2 description MONTAJE
neighbor 2.2.2.2 update-source Loopback0
neighbor 3.3.3.3 remote-as 22927
neighbor 3.3.3.3 description MONTAJE
neighbor 3.3.3.3 update-source Loopback0
address-family ipv4
neighbor 2.2.2.2 activate
neighbor 2.2.2.2 soft-reconfiguration inbound
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 soft-reconfiguration inbound
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 2.2.2.2 send-community both
neighbor 2.2.2.2 route-reflector-client
neighbor 2.2.2.2 next-hop-self
neighbor 2.2.2.2 maximum-prefix 100
neighbor 3.3.3.3 send-community both
neighbor 3.3.3.3 route-reflector-client
neighbor 3.3.3.3 next-hop-self
exit-address-family
address-family ipv4 vrf VRF-MONTAJE
redistribute connected
redistribute static
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf VRF-MGMT
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf VRF-BODY
no auto-summary
no synchronization
exit-address-family
ip classless
no ip http server
no ip http secure-server
logging alarm informational
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login local
transport input ssh
end
CORE#
CORE#
H10#SH RUNning-config
Current configuration : 3551 bytes
version 12.4
hostname H10
boot-start-marker
boot-end-marker
enable secret 5 $1$J/LH$OTW2MUPG7HGXB.O4Pwzo1.
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip vrf VRF-BODY
rd 22927:30
ip vrf VRF-MGMT
rd 22927:10
ip vrf VRF-MONTAJE
rd 22927:20
route-target import 22927:2030
no ip domain lookup
ip ssh version 2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip ospf 1 area 0
interface Loopback1
description PLANO CONTROL VRF OSPF 36
ip address 12.12.12.12 255.255.255.255
interface Loopback2
description RED1
no ip address
interface Loopback3
description RED2
no ip address
interface Loopback37
description PREFIJO_TEST_VRF_CONNECT_BGP
ip address 172.16.37.1 255.255.255.240
description CORE
ip address 172.16.24.110 255.255.255.252
ip ospf 1 area 0
duplex half
mpls ip
description A1
ip address 172.16.36.1 255.255.255.240
duplex full
router ospf 36 vrf VRF-MONTAJE
router-id 12.12.12.12
capability vrf-lite
network 12.12.12.12 0.0.0.0 area 0
network 172.16.36.0 0.0.0.15 area 0
default-information originate
router ospf 1
router-id 2.2.2.2
router ospf 22927
router bgp 22927
bgp router-id 2.2.2.2
neighbor 1.1.1.1 remote-as 22927
neighbor 1.1.1.1 description MONTAJE
neighbor 1.1.1.1 update-source Loopback0
address-family ipv4
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 soft-reconfiguration inbound
no auto-summary
no synchronization
exit-address-family
neighbor 1.1.1.1 send-community both
neighbor 1.1.1.1 next-hop-self
exit-address-family
redistribute static
redistribute ospf 36 vrf VRF-MONTAJE match internal external 1 external 2
no auto-summary
no synchronization
exit-address-family
no auto-summary
no synchronization
exit-address-family
no auto-summary
no synchronization
exit-address-family
ip classless
no ip http server
ip access-list standard permitetodo
ip prefix-list 10 seq 5 permit 0.0.0.0/0
ip prefix-list permitetodo seq 10 permit 0.0.0.0/0
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login local
transport input ssh
end
H10#
B-4#SH RUN
B-4#SH RUNning-config
Current configuration : 2464 bytes
version 12.4
hostname B-4
boot-start-marker
boot-end-marker
enable secret 5 $1$GLlu$1Ok1RIUOpKCvvjVJ2Rtdw/
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip vrf VRF-BODY
rd 22927:30
ip vrf VRF-MGMT
rd 22927:10
ip vrf VRF-MONTAJE
rd 22927:20
route-target export 22927:2030
no ip domain lookup
ip ssh version 2
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip ospf 1 area 0
no ip address
shutdown
duplex half
description CORE
ip address 172.16.24.114 255.255.255.252
ip ospf 1 area 0
duplex half
mpls ip
router ospf 1
router-id 3.3.3.3
router bgp 22927
no synchronization
bgp router-id 3.3.3.3
no auto-summary
exit-address-family
no auto-summary
no synchronization
exit-address-family
no auto-summary
no synchronization
exit-address-family
no auto-summary
no synchronization
exit-address-family
ip classless
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login local
transport input ssh
end
B-4#
R1#SH RUN
R1#SH RUNning-config
Current configuration : 2906 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip vrf ospf_montaje
rd 36:1
no ip domain lookup
interface Loopback0
ip vrf forwarding ospf_montaje
ip address 5.5.5.5 255.255.255.255
interface Loopback2
description RED1
ip address 172.16.36.17 255.255.255.248
interface Loopback3
description RED2
ip address 172.16.36.33 255.255.255.248
no ip address
description H10
ip address 172.16.36.2 255.255.255.240
duplex full
interface GigabitEthernet1/0
no ip address
shutdown
negotiation auto
router ospf 36 vrf ospf_montaje
router-id 5.5.5.5
capability vrf-lite
network 5.5.5.5 0.0.0.0 area 0
network 172.16.36.16 0.0.0.7 area 0
network 172.16.36.32 0.0.0.7 area 0
ip classless
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
2 RESPUESTAS 2
Jose Suarez
I copy a link that you can use as a reference:
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/13733-mpls-vpn-basic.html
Jose Suarez
CCIE No. 66421
Thank  you so much José.
Have Nice day
