cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
No puedo habilitar lanbase-routing
derek1804
Buenas tardes,
Tengo un Swtich cisco catalyst 2960-s series SI
SW Version 12.2(55)SE5
No me acepta el comando sdm prefer lanbase-routing.
Alguien sabe si mi version de sofware acepta esta modalidad en la plantilla SDM.
Segun esta guia dice para version 12.2(55)SE  http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swsdm.html
Pero no se si porque la mia diga 12.2(55)SE5 no se pueda.
Espero alguien me ayude, mil gracias.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Gracias por la información Derek. El equipo que tienes viene con la licencia Lan Lite por lo que no va a soportar esta configuración:
The SDM template used by Catalyst 2960-S running LAN Lite image is a default templates and is not configurable.
Tu equipo es Lan Lite:
Q. How can I tell the difference between the LAN Base and LAN Lite switches for the Cisco Catalyst 2960-S Series?
A. On the front of the switch, in the top right corner, the LAN Lite  switches have "Catalyst 2960-S Series SI." The LAN Base switches have  "Catalyst 2960-S Series."
From  the rear of the Cisco Catalyst 2960-S Series Switch, the LAN Lite  models do not support stacking. The left side will not have a location  for the FlexStack module to be inserted.
From the Cisco IOS® Software command line, there are two ways to tell which software image the switch has.
1. The last letter in the product ID. If the last letter is "-L," it's LAN Base. If it's "-S," it's LAN Lite.
For example:
  WS-C2960S-48LPS-L is LAN Base.
WS-C2960S-48TS-S is LAN Lite.
2.  The output from the "show license" Cisco IOS Software command-line  interface (CLI) command. If LAN Base is being used, that will be the  active license. If it's LAN Lite, that will be the active license. In  the following example output, LAN Base is the active license.
C2960-S_Switch# show license
Index 1 Feature: lanlite
Period left: 0 minute 0 second
Index 2 Feature: lanbase
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
License Count: Non-Counted
Q. Do I need a software license for Cisco Catalyst 2960-S Series Switches?
A. No. Cisco Catalyst 2960-S Series Switches use the Universal image, but  no license is required. The feature is bound to the hardware model type  and cannot be changed.
For  convenience, a single software image is used for all Cisco Catalyst  2960-S Series Switches, regardless of whether they are a LAN Base or LAN  Lite model.
Q. Can a Cisco Catalyst 2960-S Series LAN Lite switch be upgraded to LAN Base?
A. No. The feature set is bound to the hardware model. To get the features  and capabilities of LAN Base, you must purchase a LAN Base switch.
Cisco Catalyst 2960 and 2960-S Series Switches
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-577519.html
Déjame saber si esta información te sirve.
Saludos,
Bernardo
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
bzendeja
Hola Derek,
Checando  el link que usaste de referencia podemos ver que para soportar ese  template necesitas estar corriendo la imagen lan base:
Catalyst 2960-S switches running the LAN base image support only a default template and the lanbase-routing template.
The  lanbase-routing template is supported only on switches running Cisco  IOS Release 12.2(55)SE or later and the LAN base image.
¿Tu switch está corriendo este feature set? Puedes anexar un show version o lo puedes validar en el sitio de feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Déjame saber si esta información te ayuda.
Saludos,
Bernardo
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE5,
RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 19:22 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWA
RE (fc1)
Switch uptime is 2 hours, 20 minutes
System image file is "flash:/c2960s-universalk9-mz.122-55.SE5/c2960s-universalk9
-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48TS-S (PowerPC) processor (revision G0) with 131072K bytes of m
emory.
Processor board ID FOC1704W2C7
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
50 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 20:BB:C0:80:6E:00
Motherboard assembly number : 73-12424-08
Power supply part number : 341-0327-04
Motherboard serial number : FOC17040VMY
Power supply serial number : LIT16510806
Model revision number : G0
Motherboard revision number : A0
Model number : WS-C2960S-48TS-S
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC17040GGT
System serial number : FOC1704W2C7
Top Assembly Part Number : 800-32452-05
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number : COMGK00ARE
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960S-48TS-S 12.2(55)SE5 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Mil Gracias
For example:
Saludos,
Bernardo
Muchas Gracias por su ayuda. Tendre que usar otro dispositivo para enrutar mis vlans. Gracias
