cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Problema de output error en interfaz Nexus N9K-C93180YC-EX
ohjamerica
Buenas tardes,
Quisiera solicitar de su apoyo, tengo un detalle con un equipo N9K-C93180YC-EX ya que en las interfaces que se encuentran en UP se observan output errors, he limpiado contadores y estos vuelven a incrementarse.
MXMEXSWINT9002# sh int eth1/11
Ethernet1/11 is up
admin state is up, Dedicated Interface
Hardware: 1000/10000/25000 Ethernet, address: 2c33.113a.9c66 (bia 2c33.113a.9c66)
Description: F5_VPN
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned on, FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped 1week(s) 3day(s)
Last clearing of "show interface" counters 1w1d
0 interface resets
30 seconds input rate 24432 bits/sec, 9 packets/sec
30 seconds output rate 451176 bits/sec, 217 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 24.38 Kbps, 9 pps; output rate 441.60 Kbps, 197 pps
RX
8608421 unicast packets 0 multicast packets 0 broadcast packets
8608421 input packets 2398000045 bytes
152851 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
67648317 unicast packets 3634859 multicast packets 3635341 broadcast packets
74926462 output packets 19060383662 bytes
176881 jumbo packets
7945 output error 0 collision 0 deferred 0 late collision --> Se ven pocos dado que el tráfico que esta pasando es mínimo.
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Si a alguien le ha pasado lo mismo y me puede sugerir que revisar de los agradeceré.
Saludos!
0 RESPUESTAS 0
