cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Router on-Stick y configurado PAT
Armando Freire
Hello, I have a problem in a network where PAT and Router-on-Stick are configured but they cannot access the internet and at the same time I have also configured a VPN tunnel connected to another network that would be the remote office but it does not work either. In R2 the router-on-stick and PAT are configured , from R2 it pings the INTERNET network but the other devices do not.
R1 HEAD OFFICE
Current configuration : 3475 bytes
version 15.1
no service timestamps debug datetime msec
service password-encryption
hostname R1
login block-for 300 attempts 3 within 30
login on failure
login on success
enable secret xxx
no ip cef
no ipv6 cef
username spmunu secret xxx
license udi pid CISCO2911/K9 sn xxx
ip domain-name lasociados.com
ip name-server 70.0.0.38
spanning-tree mode pvst
interface Tunnel0
ip address 172.16.0.1 255.255.255.252
mtu 1476
tunnel source Serial0/0/0
tunnel destination 90.0.0.1
Gigabit Ethernet0/0 interface
ip address 192.168.1.254 255.255.255.248
ip access-group OUTSIDE in
ip nat inside
duplex car
speed car
Gigabit Ethernet0/1 interface
no ip address
duplex car
speed car
shutdown
Gigabit Ethernet0/2 interface
no ip address
duplex car
speed car
shutdown
interface Serial0/0/0
ip address 80.0.0.1 255.255.255.0
ip access-group INSIDE in
ip nat outside
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ospf router 1
log-adjacency-changes
network 192.168.1.0 0.0.0.255 area 0
network 172.16.0.0 0.0.0.3 area 0
ip nat inside source list 1 interface Serial0/0/0 overload
ip nat inside source static tcp 192.168.1.130 80 80.0.0.1 80
ip nat inside source static tcp 192.168.1.130 443 80.0.0.1 443
classless ip
ip route 90.0.0.0 255.255.255.0 80.0.0.2
ip route 192.168.1.0 255.255.255.128 192.168.1.253
ip route 192.168.1.128 255.255.255.224 192.168.1.253
ip route 192.168.1.160 255.255.255.240 192.168.1.253
ip route 192.168.1.240 255.255.255.248 192.168.1.253
ip route 70.0.0.0 255.255.255.0 80.0.0.2
ip flow-export version 9
ip access list extended sl_def_acl
deny tcp any any eq telnet
deny tcp any any eq www
deny tcp any any eq 22
permit tcp any any eq 22
access-list 1 permit 192.168.1.0 0.0.0.255
ip access-list standard VTY
allow 192.168.1.160 0.0.0.15
deny any
ip access-list extended INSIDE
allow tcp 70.0.0.0 0.0.0.255 host 80.0.0.1 eq 443
deny tcp 70.0.0.0 0.0.0.255 host 80.0.0.1 eq www
permit tcp 70.0.0.0 0.0.0.255 any established
permit icmp 172.16.0.0 0.0.255.255 192.168.1.0 0.0.0.255
permit icmp 70.0.0.0 0.0.0.255 any echo-reply
deny ip any any
ip access list extended OUTSIDE
permit icmp 192.168.1.0 0.0.0.255 any
permit tcp 192.168.1.0 0.0.0.255 any eq www
allow tcp 192.168.1.0 0.0.0.255 any eq 443
permit tcp 192.168.1.0 0.0.0.255 any established
deny ip any any
banner motd ^C
************ RH LOPEZ AND ASSOCIATES ********************
*** Unauthorized access to the device ***************
*** is punishable by international law. *********
** If you are not authorized, log out immediately ****
^C
logging trap debugging
record 192.168.1.132
line con 0
password xxx
login
line aux 0
line vty 0 4
access-class VTY in
exec-timeout 5 30
local login
transport input ssh
line vty 5 15
access-class VTY in
exec-timeout 5 30
local login
transport input ssh
ntp server 80.0.0.2
ntp update-calendar
end
R2 REMOTE OFFICE
version 15.1
hostname R2
login on failure
login on success
ip dhcp excluded-address 172.20.0.62
ip dhcp excluded-address 172.20.0.30
ip dhcp excluded-address 172.20.0.1 172.20.0.3
ip dhcp pool Factory
network 172.20.0.0 255.255.255.224
default-router 172.20.0.30
dns-server 192.168.1.130
ip dhcp pool Distribution
network 172.20.0.32 255.255.255.224
default-router 172.20.0.62
no ip cef
no ipv6 cef
interface Tunnel0
ip address 172.16.0.2 255.255.255.252
mtu 1476
tunnel destination 80.0.0.1
description Connection to S4 with TRUNK
no ip address
ip nat inside
duplex car
speed car
Gigabit Ethernet0/0.10 interface
description VLAN of the Factory department
encapsulation dot1Q 10
ip address 172.20.0.30 255.255.255.224
interface Gigabit Ethernet0/0.20
description VLAN of the Distribution department
encapsulation dot1Q 20
ip address 172.20.0.62 255.255.255.224
interface Gigabit Ethernet0/0.99
ADM Vlan description
encapsulation dot1Q 99 native
ip address 172.20.0.254 255.255.255.248
no ip address
duplex car
speed car
shutdown
no ip address
duplex car
speed car
shutdown
ip address 90.0.0.1 255.255.255.0
ip nat outside
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ospf router 1
network 172.20.0.0 0.0.0.255 area 0
rip router
classless ip
ip route 70.0.0.0 255.255.255.0 90.0.0.2
ip route 80.0.0.0 255.255.255.0 90.0.0.2
access-list 1 permit 172.20.0.0 0.0.0.255
no cdp run
banner motd ^C
^C
line con 0
line aux 0
line vty 0 4
exec-timeout 5 30
login
line vty 5 15
exec-timeout 5 30
login
ntp server 90.0.0.2
end
2 SOLUCIONES ACEPTADAS
Soluciones aceptadas
Jose Suarez
The 'ip nat inside' command has to be placed on the subinterfaces, not on the main interface.
R2(config)#int gigabitEthernet 0/0
R2(config-if)#no ip nat in
R2(config-if)#no ip nat inside
R2(config-if)#exit
R2(config)#int gigabitEthernet 0/0.20
R2(config-subif)#ip nat inside
R2#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 90.0.0.1:20 172.20.0.35:20 70.0.0.1:20 70.0.0.1:20
icmp 90.0.0.1:21 172.20.0.35:21 70.0.0.1:21 70.0.0.1:21
icmp 90.0.0.1:22 172.20.0.35:22 70.0.0.1:22 70.0.0.1:22
C:\>ipconfig
FastEthernet0 Connection:(default port)
Connection-specific DNS Suffix..:
Link-local IPv6 Address.........: FE80::203:E4FF:FEAC:378
IPv6 Address....................: ::
IPv4 Address....................: 172.20.0.35
Subnet Mask.....................: 255.255.255.224
Default Gateway.................: ::172.20.0.62
C:\>ping 70.0.0.1
Pinging 70.0.0.1 with 32 bytes of data:
Reply from 70.0.0.1: bytes=32 time=2ms TTL=253
Reply from 70.0.0.1: bytes=32 time=21ms TTL=253
Ping statistics for 70.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 21ms, Average = 6ms
Jose Suarez
CCIE No. 66421
Ver la solución en mensaje original publicado
Jose Suarez
The problem with the tunnel was in the ACL in R1, that didn't allow GRE traffic.
permit tcp 70.0.0.0 0.0.0.255 host 80.0.0.1 eq 443
permit icmp any any echo
permit gre any any
deny ip any any
R1#sh ip route ospf
172.20.0.0/16 is variably subnetted, 3 subnets, 2 masks
O 172.20.0.0 [110/1001] via 172.16.0.2, 00:03:43, Tunnel0
O 172.20.0.32 [110/1001] via 172.16.0.2, 00:03:43, Tunnel0
O 172.20.0.248 [110/1001] via 172.16.0.2, 00:03:43, Tunnel0
"I hope this is helpful to you. Remember to support with a like, and if this solves your question, please select it as the chosen answer."
Jose Suarez
CCIE No. 66421
3 RESPUESTAS 3
Jose Suarez
R2(config-if)#exit
C:\>ipconfig
C:\>ping 70.0.0.1
Jose Suarez
CCIE No. 66421
Jose Suarez
permit gre any any
deny ip any any
R1#sh ip route ospf
Jose Suarez
CCIE No. 66421
Thank you very much @Jose Suarez
