cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
6
ÚTIL
17
Respuestas
VLAN 10,20,30 not connect to dns and http
OGUZZZ
hii ,
I can't connect to the dns and http server on my network.
can you help, thanks
17 RESPUESTAS 17
Of course the vlan will communicate with each other. That's the whole idea of networking.  If you want to segregate the network you need to use either a firewall or Access List.
Button line here my friend, to finish this conversation. Your topology was not working, at least on the first file you attached and now, at least on the file I have in my machine, it is fully functional.
You did not say anything about vlan can not communicate until now. But, it is up to you of course.  I wish you all the best on your study and I hope I could contribute a little bit with that.
Make the changes you need, explore and good learning to you.
cheers!
How many subnets are you using on the right side (servers) ?
If you have 2 subnets for the servers you must do as i mentioned above, similar as you did on the computer side.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
10.10.10.4 DNS
10.10.10.3 HTTP
GATEWAY 10.10.10.1
SUBNET MASK 255.255.255.0
I DON'T UNDERSTAND WHAT YOU MEAN, BUT THERE IS ONE SUBNET
