cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Adding threat-detection basic-threat
Hi All,
Would the addition of the command "threat-detection basic-threat" cause any issues with legitimate login requests from users that are connecting through Cisco AnyConnect intending to use 2FA?
The feature is enabled by default but is there any impact for VPN users that you are aware of?
This is for ASA5525.
Marco J.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
M02@rt37
Hello @MarcoJimenez37276,
THe basic-threat detection feature is designed to detect and log potential threats, and it should not interfere with legitimate user traffic. It relies on predefined signatures and heuristics to detect potential threats. In some cases, legitimate traffic patterns may trigger false positives, leading to logs and notifications. It's important to review the logs periodically to ensure no legitimate activities are being flagged incorrectly.
Regarding VPN users connecting through Cisco AnyConnect and using 2FA , the "threat-detection basic-threat" command should not directly impact this functionality. However, it's important to ensure that the AnyConnect configuration & the 2Fa mechanism are prperly implemented and functioning as intended.
Best regards
Ver la solución en mensaje original publicado
1 RESPUESTA 1
M02@rt37
Best regards
