cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Storage capacity (SSD) for my Cisco AMP 8390 hardware dedicated
GPumasupa
Hi everybody,
I have a query for this kind of storage capacity,
Cisco says "SSD 1600 GB+" so I wanna know what it is means?
Just 1600 GB or something more because of "+"?
Thanks for helping us.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hi @GPumasupa ,
The initial capacity is the one indicated in the image you attach.
This capacity can be increased with a second SSD (malware storage pack).
Check this link:
https://www.cisco.com/c/en/us/td/docs/security/firepower/hw/maintenance/firepower-8000/firepower_8k_device.pdf
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
The "+" means higher, so the SSD capacity can be 1.6TB or higher (2TB, 3TB, etc).
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for helping, so we dont know the exactly storage capacity?
Hi @GPumasupa ,
Check this link:
Hilda Arteaga
hi @GPumasupa
Thanks for extending your doubt in the Community.
If you wish you can post your questions in Spanish as well
