cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
9
Respuestas
VPN IPsec using loopback peer encaps and decaps only from router
pdasilva
I am setting up a site to site vpn between a checkpoint firewall and a cisco router, since the router has multiple wans using dynamic routing, I decided to use the loopback as a peer, the tunnel goes up to phase two, and I can make the traffic from the router come out encrypted, but the hosts that are on the same network cannot be encrypted tha pacekts from host  are not encaps. When the traffic is initiated from the checkpoint the packets arrive at the router, they are decaps but the value of encaps does not increase
crypto isakmp policy 3382
encr aes 256
hash sha256
authentication pre-share
group 14
lifetime 1800
crypto isakmp key ^2f5%3edfBxO15BDS2g!M76&sr206k7G address 106.1.20.1
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set VPN_1 esp-aes 256 esp-sha256-hmac
mode transport
crypto map VPN_BBVA local-address Loopback3
crypto map VPN_BBVA 3382 ipsec-isakmp
set peer 106.1.20.1
set transform-set VPN_1
match address 110
interface Loopback3
description VPN
ip address 107.33.82.12 255.255.255.255
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
crypto map VPN_BBVA
interface GigabitEthernet0/0
description Conexion LAN
ip address 109.33.82.1 255.255.255.0
ip accounting output-packets
ip nbar protocol-discovery
ip nat inside
load-interval 60
duplex auto
speed auto
access-list 110 permit ip 109.33.82.0 0.0.0.255 106.33.201.0 0.0.0.255
route-map nonat permit 10
match ip address VPN_NONAT
set ip next-hop 107.33.82.12
ip nat inside source route-map nonat interface Loopback3 overload
ip route 106.33.201.0 255.255.255.0 Loopback3
ip access-list extended VPN_NONAT
deny ip 109.33.82.0 0.0.0.255 106.33.201.0 0.0.0.255
permit ip 109.33.82.0 0.0.0.255 any
2 SOLUCIONES ACEPTADAS
Soluciones aceptadas
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
crypto isakmp policy 10
hash md5
crypto isakmp key mhm address 150.0.0.3
crypto ipsec transform-set mhm esp-des
mode tunnel
crypto map mhm local-address Loopback0
crypto map mhm 10 ipsec-isakmp
set peer 150.0.0.3
set transform-set mhm
match address 100
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 100.0.0.1 255.255.255.0
duplex full
crypto map mhm
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
ip address 110.0.0.1 255.255.255.0
speed auto
duplex auto
crypto map mhm
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
serial restart-delay 0
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
interface GigabitEthernet4/0
ip address 10.0.0.1 255.255.255.0
ip policy route-map mhm
negotiation auto
router ospf 100
network 1.1.1.1 0.0.0.0 area 0
network 100.0.0.0 0.0.0.255 area 0
network 110.0.0.0 0.0.0.255 area 0
router bgp 100
bgp log-neighbor-changes
network 10.0.0.0 mask 255.255.255.0
neighbor 150.0.0.3 remote-as 200
neighbor 150.0.0.3 ebgp-multihop 255
neighbor 150.0.0.3 update-source Loopback0
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 100 permit ip 10.0.0.0 0.0.0.255 20.0.0.0 0.0.0.255
route-map mhm permit 10
set interface Loopback0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
I do lab solve your issue
please take look about how I config IPsec using LO in one side.
NOTE:- you need BGP to override the routing issue of using LO
Ver la solución en mensaje original publicado
9 RESPUESTAS 9
sorry but I see only one route toward Loopback ?
pdasilva
the route corresponds to the encryption domain on the checkpoint side, the loopback is known over the network using eigrp and ospf
are the Checkpoint use LO as Peer IP ??
interface Loopback3
ip nat outside
crypto map VPN_BBVA
ip nat inside
access-list 110 permit ip 109.33.82.0 0.0.0.255 106.33.201.0 0.0.0.255 <- the interest traffic match the LAN subnet but you also use NAT ? why you use NAT ?
let me send a little diagram
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
hash md5
mode tunnel
set peer 150.0.0.3
match address 100
interface Loopback0
duplex full
crypto map mhm
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
crypto map mhm
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
negotiation auto
router ospf 100
router bgp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
Thank you very much, I will try to use this solution and I will tell you the results.
You are so so welcome
