cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Multigigabitports
Hello everyone, how are you? I'm looking into the port range of the Cisco Catalyst C9200-48PXG-A switch, specifically identifying which ports support Multigigabit. So far, I haven't found this information in the documentation, such as the datasheet.
Could someone assist me with this? I'm curious to know if these Multigigabit ports are explicitly marked on the switch.
Thanks for your help!
3 RESPOSTAS 3
nict
Hi Gabriel,
Really good question. I haven't any experience myself with the C9200 PXG switches, but I came across this: 9200L-24PXG multigigabit ports.
So it is likely that you see a blue line under the interfaces and/or see the interfaces as "te x/x/x" on the switch.
I will agree with you, finding documentation about this is really not easy.
balaji.bandi
C9200-48PXG-A
Catalyst 9200 48-port 8xmGig, 40x1G, PoE+, Network Advantage
There is not marked on the switch, but you can see show interface status 8 port shows support mgig.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
BB
Hello @gabriel.lima.caitano ,
looking at the 9200 switch architecture https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-architecture-cte-en.html#Frontpanelinterfaces
Fig. 14 describes the High level block diagram of the C9200-48PXG. As you can see
Ports 1 through 36 are mapped to ASIC1 and connected with 1G PHY to the ASIC
Ports 37 through 40 are mapped to ASIC1 and connected with mGig PHY to the ASIC
Ports 41 through 48 are mapped to ASIC0 and connected with mGig PHY to the ASIC
Based on this, you will have the following port numbering in the switch: GigabitEthernet1/0/1-36 and TenGigabitEthernet1/0/37-48
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
