em 11-17-2023 03:09 AM
Hello, how are you?
I have a question about the switch.
In the Health tab of the switch, there are two temperature sensors, "sensor 1" and "sensor 2." I just need to know what exactly the sensors measure and what the ideal temperature is for each sensor.
Switch model: CBS220 24T 4X
em 11-17-2023 03:20 AM
When i was looking for the same information, Cisco documentation not clear where this sensor 2 installed.
But when contacted some of the technical people in this regard i was told as long as they are controlled Temparature that should be good, when any of them have warning as exmaple below : we should look environment where this switch installed.
em 11-17-2023 03:53 AM
"It's really not clear this information.
My concern is that this switch is not in a temperature-controlled environment, only with fans."
em 11-18-2023 02:14 AM
in that case mostly you need to configure SNMP Trap or Syslog to monitor and get alert.
cisco always suggest use industrial switches where the environment no controlled using Airconditioned (based on the location)
em 11-17-2023 03:03 AM
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
Navegue pelos links rápidos da Comunidade e usufrua de um conteúdo personalizado e em seu idioma nativo:
