cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
23
Respostas
Switch de acesso com tempo de resposta elevado
Luizhen
O nosso switch está com o tempo de resposta muito alto, creio que seja por causa da inundação de DHCP, ele fica gerando log diversos logs em pouquíssimos segundos, como este abaixo:
iaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:51: DHCP_SNOOPING: message type : DHCPDISCOVER DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:51: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (60)
Aug 1 14:34:51: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/10 for pak. Was not set
Aug 1 14:34:51: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/10
Aug 1 14:34:51: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/10)
Aug 1 14:34:51: DHCP_SNOOPING: process new DHCP packet, message type: DHCPREQUEST, input interface: Gi0/10, MAC da: ffff.ffff.ffff, MAC sa: 0ee4.3cb5.5fdd, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:51: DHCP_SNOOPING: message type : DHCPREQUEST DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0ee4.3cb5.5fdd
Aug 1 14:34:54: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/10 for pak. Was not set
Aug 1 14:34:54: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/10
Aug 1 14:34:54: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/10)
Aug 1 14:34:54: DHCP_SNOOPING: process new DHCP packet, message type: DHCPREQUEST, input interface: Gi0/10, MAC da: ffff.ffff.ffff, MAC sa: d08e.79e0.18bd, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:54: DHCP_SNOOPING: message type : DHCPREQUEST DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:54: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (10)
Aug 1 14:34:55: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/10 for pak. Was not set
Aug 1 14:34:55: DHCPSNOOP(hlfm_set_if_input): Clearing if_input for pak. Was Gi0/10
Aug 1 14:34:55: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/10)
Aug 1 14:34:55: DHCP_SNOOPING: process new DHCP packet, message type: DHCPREQUEST, input interface: Gi0/10, MAC da: ffff.ffff.ffff, MAC sa: d08e.79e0.18bd, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:55: DHCP_SNOOPING: message type : DHCPREQUEST DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: d08e.79e0.18bd
Aug 1 14:34:55: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (10)
O que podemos fazer?
23 RESPOSTAS 23
SamuelGLN
@Luizhen
Todas essas vlans possuem a necessidade de receber o flood da requisição DHCP?
Aug 1 14:01:06: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (10)
Aug 1 14:01:07: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (130)
Aug 1 14:00:59: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (110)
Aug 1 14:00:49: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (60)
Aug 1 14:00:47: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (120)
Caso não seja necessário, poderia tentar utilizar o comando no ip dhcp snooping vlan X para evitar isso.
Best regards
******* If This Helps, Please Rate *******
Samuel, para eu entender melhor sobre esse configuração.
Creio que o flood de requisição DHCP vem de um dispositivo que está conectado na rede e envia um DHCPREQUEST, mas eu não sei que dispositivo é esse ou se ele de fato existe. Se é necessário ou não, não sei dizer.
Se eu utilizar esse comando eu paro o monitoramento do dhcp snooping? Se for isso é o ideal de fazer?
Detalhe: temos 46 Switches e esse é o único que está gerando esse alerta nos logs, mas nenhum está fazendo isso.
Nossa infraestrutura: Firewall L3, Switch Core L2, Switches em modo de acesso (data, voz, serviços).
@Luizhen,
De acordo com o cenário e testes que realizou, me parece mais estar relacionado com um bug no IOS (CSCuj03351). É esperado que isso funcione bem na versão 12.2.55-SE9 sem a presença do bug. Caso exista a possibilidade, aconselho que atualize um em bancada e depois siga com a atualização dos SWs em produção para evitar que isso ocorra nos demais.
Best regards
Entendi, nesse caso eu voltaria a versão? Creio que a versão do meu switch seja mais atualizada que essa.
@Luizhen realmente, não me atentei a sua versão já em produção. Estive realizando alguns testes em lab e gostaria de confirmar duas coisa:
  • Com o debug dhcp snooping ativo nos SWs em questão, você chegou a pegar algum log de DHCPINFORM para os MACs 0ee4.3cb5.5fdd; d08e.79e0.18bd?
  • As vlans 10, 130, 110, 60 e 120 estão configuradas como Ip dhcp snooping vlan x?
  • O SW_CTJL_35 possui host conectado diretamente nele que estejam utilizando alguma dessas vlans?
Best regards
Samuel, boa tarde, não rodei nenhum comando de Debug nesse switch, eu posso rodar um comando debug no switch em produção sem ter nenhum problema? Caso sim, me recomenda algum?
O DHCP Snooping está configurado nessas vlans:
Switch DHCP snooping is enabled
Switch DHCP gleaning is disabled
DHCP snooping is configured on following VLANs:
1,6,10,52,54,60,110,120,130,1000
DHCP snooping is operational on following VLANs:
Sim, o switch 35 possui conexões de várias interfaces na vlan 10, uma na vlan 60 e 3 portas trunks.
@Luizhen desculpa pela demora. A minha ideia com relação as conexões do SW35 seria a seguinte: verificar nos logs do SW38 quais MACs estão apresentando erro (por exemplo 0ee4.3cb5.5fdd; d08e.79e0.18bd) e verificar em qual interface eles estão chegando no SW35. Após isso, verifica se o dispositivo que estão com esses MACs já não possuem um IP configurado ou algum IP secundário. Pode ser que mesmo recebendo um DHCPINFORM ele apresente esses logs pois o mesmo device que faz a requisição, por algum motivo, retorna que já possui o IP atrelado.
Best regards
Segue algumas saídas que eu tive:
SW_CTJL_38# show ip dhcp snooping
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
circuit-id default format: vlan-mod-port
remote-id: 84eb.ef60.2480 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface Trusted Allow option Rate limit (pps)
GigabitEthernet0/1 no no 10
Custom circuit-ids:
GigabitEthernet0/2 no no 10
Custom circuit-ids:
GigabitEthernet0/3 no no 10
Custom circuit-ids:
GigabitEthernet0/4 no no 10
Custom circuit-ids:
GigabitEthernet0/5 no no 10
Custom circuit-ids:
GigabitEthernet0/6 no no 10
Custom circuit-ids:
GigabitEthernet0/7 no no 10
Custom circuit-ids:
GigabitEthernet0/8 no no 10
Custom circuit-ids:
GigabitEthernet0/10 yes yes unlimited
Custom circuit-ids:
Port-channel1 yes yes unlimited
Custom circuit-ids:
SW_CTJL_38#show ip dhcp snooping statistics
Packets Forwarded = 2624846
Packets Dropped = 1
Packets Dropped From untrusted ports = 0
SW_CTJL_38#show ip dhcp snooping binding
MacAddress IpAddress Lease(sec) Type VLAN Interface
40:A6:E8:53:DC:53 10.200.0.190 77624 dhcp-snooping 6 GigabitEthernet0/8
Total number of bindings: 1
SW_CTJL_38#show ip dhcp snooping database
Agent URL :
Write delay Timer : 300 seconds
Abort Timer : 300 seconds
Agent Running : No
Delay Timer Expiry : Not Running
Abort Timer Expiry : Not Running
Last Succeded Time : None
Last Failed Time : None
Last Failed Reason : No failure recorded.
Total Attempts : 0 Startup Failures : 0
Successful Transfers : 0 Failed Transfers : 0
Successful Reads : 0 Failed Reads : 0
Successful Writes : 0 Failed Writes : 0
which from these two cases you have ?
MHM
