cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
The first ip in an ipv6 network
luisfeliperm
In a scenario where the network is 2001:db8::/64
Gateway IP: 2001:db8::1/64
Hosta A: 2001:db8::2/64
If host A pings network IP 2001:db8::0 will the Gateway respond?
I mean, if there is any ping on the network for the first ip which would be ::0000/64, will the router on that network respond? My question arose because I saw some quotes that when you do a ping to the network ip, the router responds to announce that it is the network router.
1 Soluções Aceita
Soluções aceites
M02@rt37
Hello @luisfeliperm,
In IPv6, the network address (::/64 in you example) is typically not assigned to any specific device, including the router. Therefore, if a host (in this case, Host A with IP 2001:db8::2/64) pings the network address 2001:db8::/64, it is unlikely that the router will respond to such a ping.
Routers typically do not respond to pings directed at network addresses because network addresses are not meant to be assigned to individual devices. Instead, they are used for routing and subnet identification purposes.
Best regards
Ver solução na publicação original
2 RESPOSTAS 2
M02@rt37
Best regards
balaji.bandi
Not that i believe that works  - I  have not seen any time before  that works -  (Only 0 responds lf the subnet mask is different  and 0 is configured on the Router)
BB
