Avis : La fonction de téléchargement de fichiers est désactivée. Veuillez nous excuser pour la gêne occasionnée.
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
IOS XR - Forwarding a VLAN between two interfaces
axelhauguel
Hi all,
My answer is probably basic, but I need to forward a VLAN received from my upstream to my customer, on another interface.
How to do it ? Encapsulation ? Please help me with commands or link. I have eat google to see the answer but not found :((((
How to configure port on my NCS-5501-SE (IOS XR) on provider interface, and on my "LAN" interface ?
Thanks you
Axel
1 SOLUTION APPROUVÉE
Solutions approuvées
Local Switching is solution here I think
* Configure local switching on the VLAN sub-interfaces */
Router(config-l2vpn-xc)# p2p XCON1_P2P1
Router(config-l2vpn-xc-p2p)# interface TenGigE0/0/0/0.1
Router(config-l2vpn-xc-p2p)# interface TenGigE0/0/0/8.1
Router(config-l2vpn-xc-p2p)# commit
Router(config-l2vpn-xc-p2p)# exit
Router# configure
Router(config)# interface TenGigE 0/0/0/0.1 l2transport
Router(config-subif)# encapsulation dot1q 5
Router(config-subif)# exit
Router(config)# interface TenGigE 0/0/0/8.1 l2transport
Router(config-subif)# commit
 this what you need
NOTE:- repeat it for other VLAN's
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5000/vpn/60x/b-ncs5000-l2vpn-configuration-guide-60x/b-ncs5000-l2vpn-configuration-guide-60x_chapter_0100.html#concept_5F21477FEEBD4C99B016DBD89053DC96
Voir la solution dans l'envoi d'origine
4 RÉPONSES 4
axelhauguel
I have asked a friend to suggest me to use "routed VLAN" but don't know really what does it mean.
Router# configure
 this what you need
axelhauguel
Thank you @MHM Cisco World , you're always the boss ! :)))
You are so welcome
