Cisco IOx supported platforms!!
angeljack21
Community Member
Cisco IOx sounds really promising and exciting but doing some researches, I have found a lot of blogs saying that in addition to the Cisco Connected Grid Routers, CGR1120 and CGR1240, Cisco added IOx support to 16 other Cisco platforms, including the C819, C88x, C89x routers.
Which ones?!!! can someone cites them for me???!! or give me a link please?!
For example does the Cisco 3850 catalyst support IOx?!
Thank you for your help in advance,
Mehdi
7 Replies 7
kiskande
Hi  Mehdi,
did some dinging and came up with the list of IOX Supported Platform:
please view: Cisco IOx Local Manager User Guide - Cisco
Cisco is currently working on adding IOX to other platforms. once in place, supported list will be updated!
hope this helps,
-Kareem
Cheers Kareem,
Mehdi
I think, the link mentioned above focuses on 8x9 family. For example, IR910 and CGR1K are not mentioned. So, the list is complete in as far as the 8x9 family is concerned; not the complete list of IOx supported platforms.
Hi Nagesh,
For the IOx supported platforms, they are CGR1K, and 8x9 family list in Cisco IOx Local Manager User Guide.pdf. IR910 is not supported yet actually, but it will be soon.
Steve
Thanks for the clarification.
This link is no longer active.
Hello folks --
The supported platform matrix can be found on DevNet:
https://developer.cisco.com/docs/iox/#!platform-support-matrix
Emmanuel
