Creating a Yocto Image for Testing
nathan
Level 2
Level 2
I would like to create my own Yocto image tor test purposes, especially with LXC containers.
I can use the Yocto Quick Start and the Yocto Build Appliance.
When running the build appliance, which is a menu driven system for creating images, I can choose options such as:
  • profile - qemux86-64
  • recipe - core-mage-base
With the goal of creating an image that I can then run on OS X with Qemu tools installed via Homebrew.
I have started a project for that here: GitHub - DevOps4Networks/iox-yocto-build: Build scripts for a Yocto image for IOx
At this stage, I don't know what the actual recipe is for the Yocto image on the 829 though. Can you tell me what that is please?
Many thanks
Nathan
Steve Zhang
Hi Nathan,
For how to create Yocto image for IOx, it will come soon with documentation. Please stay tuned.
Stev
Checking in ... 🙂
Steve Zhang
Basically Cisco provides the IOx SDK to generated application packages including VM, PaaS and LXC style applications. Here is the reference: https://developer.cisco.com/site/iox/documents/developer-guide/?ref=quickstart and go to the yocto and SDK part for details.
