Cybersecurity Lab VM Workstation 20250409
manikantach
Hello, I am unable to start the cybersecurity lab workstation virtual machine after saved   the state of machine.
mohamad-as
I am not sure, but this may help you. Try to go into BIOS/UEFI settings and look for "secure virtual machine mode". This mostly found in AMD motherboards. If found it, enable it to see if it fixes your problem or not.
Thank you for your time sir,but already in bios settings virtualization
option is enabled sir.
