Deprecated machine type
thock
Visitor
I am atttempting to run a Linux VM in IOx on a C8200 platform.  The container log shows that it is starting with option:
-machine pc-0.13,accel=kvm,usb=off,dump-guest-core=off
and complains:
2025-10-21T17:11:14.773544Z qemu-kvm: Machine type 'pc-0.13' is deprecated: use a newer machine type instead
I really need the machine type to be pc-q35 to support my version of Linux.  Is there a way to specify the correct machine type?
IOx version is 1.20.0.3
6 Replies 6
Torbjørn
Can you share some details about your VM, package.yaml and deployment specifics/method?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
You might be able to do this in the package.yaml file https://developer.cisco.com/docs/iox/package-format/#iox-application-package this might be done in platform or qemu-args?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
thock
Visitor
The VM runs in KVM on my Ubuntu server when it is configured with pc-q35 machine type.  The app setion of my yaml file is:
app:
  cpuarch: x86_64
  type: vm
  resources:
   profile: custom
   cpu: 7406
   memory: 6144
   vcpu: 2
   network:
    - interface-name: eth0
  startup:
   ostype: Linux
   disks:
    - target-dev: hda
      file: "ESIP-UTA-10.3_Build54-KVM.qcow2"
   qemu-guest-agent: True
I looked through the Package Descriptor document and found app->startup->args but that seems to be specific to Docker startup.  I did not see anything about qemu-args.  Do you have an example of how to configure this in the yaml file? Thanks!
I dont know this be 100% correct, i found this on GH
    qemu-args:
      - "-machine"
      - "pc-q35"
      - "-usb" # Example of another optional argument
      - "-device"
      - "usb-tablet"
This looks like what I would want to use.  Unfortunately, the schema that Cisco uses to parse the yaml file doesn't support qemu-args.
@thock ... gah..... ok i am fresh out of ideas then, i dont even know if you could get the level of access to update the libvirt XML file.
