how do I start local manager (LM) on my local host?
venkatsubbu44
I have CAF running succesffuly on my localhost. I am also able to use the ioxclient tool to connect with the CAF instance running and perform app actions on it.
I'm able to connect to https://127.0.0.1:8443 from my browser for the LM instance. However, it just shows me a blank page, with just a page title of 'Cisco Application Management'.
I tried running 'make' from within iox-dev/core/lm/scripts/ and I run into bunch of XMT or dojo specific error (I'm no expert in XMT or Dojo).
Example error messages:
error(303) Missing include module for layer. missing: xwt/widget/Background; layer: app/layers/main
error(303) Missing include module for layer. missing: xwt/widget/navigation/UIshellV15; layer: app/layers/main
final messages:
Report written to /home/vensubr3/iox-dev/obj/core/lm/build/release/static/localmgmt/xwt-bundle/build-report.txt
Process finished normally.
  errors: 34
  warnings: 65
  build time: 81.726 seconds
make: *** [/home/vensubr3/iox-dev/obj/core/lm/build/release/static/localmgmt/xwt-bundle/app/layers/main.js] Error 1
Any help around starting/accessing a successful LM instance on the local instance along with CAF would be appreciated.
Thank You.
Steve Zhang
Hi Venkatachalam,
Are you using a non-English version Chrome? Please use English version.
Re: localmanager UI not starting, some js not found
By the way, please make sure the below things also.
- please configure the networking correctly.
- if you are using NAT, please set the related PAT.
