How to convert ModbusTCP to ModbusRTU on IR809
t_one_cisco
Hi guys
I have Cisco IR809 and would like to set modbus gateway to convert ModbusTCP packet to ModbusRTU that direct attached on interface async 0.
MODBUS/RTU(Slave)------------(rs485)----------IR809---------------(ethernet)------------MODBUS/TCP(Master)
I tried to use raw-socket but it look like when the Slave receive message it is MODBUS/TCP message, it shows bad CRC. I think the Cisco809 have to convert the TCP to RTU. I tried to read the solution of IOX but I can not fine the work configuration and code.
Please help..:)
sabin.posea
My name is Sabin Posea. We have an application called ES200 that runs on the IOx and can solve the problem. Our solution is CISCO Copmatible and listed on Cisco Marketplace
https://marketplace.cisco.com/catalog/companies/eximprod-grup-srl
You can contact me for more details by email sabin.posea@epg.ro or phone +40728.993.795
