%IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
cvailler
I do receive this message in loop.
What is the problem ?
Sep 29 16:05:14.125: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:05:14.333: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:05:25.920: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:05:26.126: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:05:37.770: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:05:37.978: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:05:49.622: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:05:49.828: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:06:01.419: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:06:01.627: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:06:13.507: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:06:13.715: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:06:15.274: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:06:15.480: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:06:25.345: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Sep 29 16:06:25.551: %IOX-6-SOCK_SEND: Sending IOX_REQUEST_RESPONSE resp with opcode IOX_REQUEST_GET_PROTECT_KEY to IOX Client
Sep 29 16:06:37.223: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client
Host registered:
IOX Server Address: FE80::200:CFF:FEC9:F189; Port: 22222
Link Local Address of Host: FE80::1FF:FE90:8B05
IPV4 Address of Host: 192.168.99.1
IPV6 Address of Host: fe80::1ff:fe90:8b05
Client Version: 0.4
Session ID: 17
OS Nodename: IR809_JMX2017X05G-GOS-1
Host Hardware Vendor: Cisco Systems, Inc.
Host Hardware Version: 1.0
Host Card Type: not implemented
Host OS Version: 1.11.0.5
OS status: RUNNING
karsb
I am also facing the same issue, Can you please help check with anyone?
Flo Pachinger
@karsb Are you using the IR809? Be ware that this product is already EOS.
I would check if you have the latest IOx version installed (from software.cisco.com). Also double check if the IOS configuration is correct as stated here https://developer.cisco.com/docs/iox
Double check if you can access CAF from the IOS interface. Can you access the local manager? You can also try the command "clear iox" if available to reset IOx.
