Edge Computing Infrastructure
Labels
Hello community,I'm encountering an issue while trying to run an RS485 Modbus RTU script on a Cisco IR1835 router. The script is designed to collect flow sensor data and send it to Azure IoT Hub. I'm hoping someone can help me troubleshoot this probl...
atheerth by • Visitor
  • 3607 Views
  • 3 replies
Dear cisco community,I am fairly new to the IOx platform.I am currently working on deploying a nodejs application on the Cisco IR829. I followed the tutorial on DEVNET to deploy a simple nodejs application on the IR829 and was able to successfully fo...
yousuf98 by • Community Member
  • 2724 Views
  • 2 replies
Hello,I do receive this message in loop.    What is the problem ?  Sep 29 16:05:14.125: %IOX-6-SOCK_MESSAGE: Received IOX_REQUEST message with opcode IOX_REQUEST_GET_PROTECT_KEY from IOX Client Sep 29 16:05:14.333: %IOX-6-SOCK_SEND: Sending IOX_REQUE...
cvailler by • Cisco Employee
  • 2572 Views
  • 2 replies
Release Notes for Cisco IOS Release 15.6(1)T for the Cisco IR800 Industrial Integrated Services Routers - CiscoThe release notes above explain that the IR809 must be reset by holding the reset button when the router is being powered up.Note that, unl...
nathan by • Level 2
  • 3693 Views
  • 1 replies
  • 5 Helpful votes
