IOX application memory increase continously
vikbhati
I am deploying an application on IR829 router. I am using docker type application and creating docker image and then creating package tar and deploying on 829 router using iox client.
I  need to run this application in tiny profile I.e it should not exceed 32 mb memory.
But the application memory(as seen in app info tab) starts from 28mb and increases continously till it reaches 32 mb. Here the  application starts responding slowly.
I Have checked that my application heap memory is in control and revolves around 10mb.
I Need pointers on how to debug this increase in application memory.
Aby pointers would be really appreciate.
VIkas Bhatia
Steve Zhang
My guess is that the issue is caused by your app.
You may refer to https://developer.cisco.com/docs/iox/#!debuggability-and-diagnostics for how to debug IOx apps.
