Edge Computing Infrastructure
Labels
Hello,I have installed IOS version 15.7 on my IR809.I thought I coud get access to the USB port from container application console, but it's not the case : I do have the same output even I'm connecting or disconnecting my arduino from the USB port./d...
cvailler by • Cisco Employee
  • 2505 Views
  • 2 replies
Hi,I have a problem with the IR809G. The router stucks in the rommon-2.This is the output in putty:<3> [0.753643] IOAPIC: IOAPIC 1 initialized, implementation version 32<3> [0.753643] <E1000> e1000_device_init: initialized E1000 device<3> [0.753643] ...
Hello,I'm trying to use the USB port as serial.And this error message I receive when trying to activate the application with the JSON file : ioxclient app activate lxcusbread --payload dev_map.jsonCurrently active profile :  IR809-4GCommand Name: app...
  • 2670 Views
  • 2 replies
I'm unable to log into the guest os on our IR829. Following the latest Software Configuration Guide I can telnet to it at 10.1.2.1 2070, but root/<blank>, cisco or other combinations will not allow me to log in.  I also tried the command, "iox host e...
toddp by • Frequent Visitor
  • 2508 Views
  • 1 replies
