ISR 1100 & hosting debian lxc is this possible?
inkubus
Hi all,
I would like to host a custom Debian lxc on ISR 1100 platform. Ultimately, I would like to host something like perSONAR, but this is an open question on what is possible? Has someone been successful hosting a custom app on ISR 1100 series, not using the builtin guestshell?
I tried multiple os versions (16.9.3 / 16.12.5 / 17.03.04) but it seems like Docker is disabled - output form ioxclient show platform info:
```"docker_version": "Not Supported",```
I can enable and run guestshell no problems, but this image has some limitations to it.
Is it possible to swap the guestshell to something different? If yes, can someone point me in the right direction?
Alexander Stevenson
Hello @inkubus,
According tho the ISR 1100-4G/4GLTE/6G Data Sheet, the following releases are supported:
Series
Releases supported
ISR 1100 Series
●  Viptela Operating system release version 19.2 and above.
●  IOS XE SD-WAN Operating system release version 17.4.1 and above in controller mode
ISR 1100X Series
●  Viptela Operating system release version 20.4 and above
For more information regarding the guestshell, we can check the Programmability Configuration Guide, Cisco IOS XE Bengaluru 17.4.x. Be careful, as it's spelled 'guestshell' sometimes and 'guest shell' others. This is the PDF version.
The online version may be better for you: Programmability Configuration Guide, Cisco IOS XE Bengaluru 17.4.x - Chapter: Guest Shell.
Best regards,
                    Alex
