03-27-2019 06:20 AM
The issue is that the generic serial USB devices are not correctly recognized and cannot be used within a docker.
The issue comes from CAF during USB device detection - in the "usb_device_access.pyc" module of CAF.
Tested 3 different devices from a different manufacturer and they exhibit exactly the same behavior.
Gest-OS detects them as USB serial device and correclty assign them to /dev/ttyACM0 of /dev/ttyUSB0.
A native program in the Guest-OS can use them correctly.
Diagnosis:
CAF detect them as serial device (through the scan of /dev/tty*), but when it tries to detect if they are generic devices, it fails and does not set the "is_generic" attributes to True and hence cannot be assign to docker application.
Debug Logs:
2019-03-27 10:07:52,767 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:34 - usbdev_hotplug_handler()]
usbdev_hotplug_handler action add dev_node /dev/bus/usb/002/003, usb_device
2019-03-27 10:07:52,785 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:49 - usbdev_hotplug_handler()] .... event: add -
/dev/bus/usb/002/003 under usb2
2019-03-27 10:07:52,786 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:512 - add_device()] add_device method ...
2019-03-27 10:07:52,874 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:539 - add_device()] First time USB insertion,
waiting 5 seconds for fs detection
2019-03-27 10:07:57,907 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:560 - add_device()] ttydevices detected:
[Device(u'/sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1/2-1:1.0/tty/ttyACM0')]
2019-03-27 10:07:57,909 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:564 - add_device()] ....hot-adding device
/dev/bus/usb/002/003 vid 0483, pid 5740 to port usb2
2019-03-27 10:07:57,910 [pdservices:INFO] [Thread-4]
[usb_device_access.py:226 - discover_other_interfaces()] discover other
interfaces()
2019-03-27 10:07:57,911 [pdservices:INFO] [Thread-4]
[usb_device_access.py:229 - discover_other_interfaces()] discover other
interfaces(2), /sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1
2019-03-27 10:07:57,912 [pdservices:INFO] [Thread-4]
[usb_device_access.py:235 - discover_other_interfaces()] discover other
interfaces(3), with len: 1
2019-03-27 10:07:57,914 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:242 - discover_other_interfaces()] discover other
interfaces(4),
Device(u'/sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1/2-1:1.0/tty/ttyACM0'),
/sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1,
2019-03-27 10:07:57,915 [pdservices:DEBUG] [Thread-4]
[usb_device_access.py:243 - discover_other_interfaces()] discover other
(5), /sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1/2-1:1.0/tty/ttyACM0
2019-03-27 10:07:57,916 [pdservices:INFO] [Thread-4]
[usb_device_access.py:255 - discover_other_interfaces()] The device
/sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1 has serial interface.
Updated details..
2019-03-27 10:07:57,917 [pdservices:INFO] [Thread-4]
[usb_device_access.py:256 - discover_other_interfaces()] USB generic
Parameters : {}
IOX Client listing the device as;
"usbdev": [
"available": true,
"bus": "2",
"dev": "3",
"device_class": "02\n",
"device_id": "/dev/bus/usb/002/003",
"device_name": null,
"device_path": "/sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1",
"generic_params": {},
"is_generic": false,
"is_storage": false,
"pid": "5740",
"port": null,
"storage_params": null,
"support_fstype": [
"vfat"
"type": "usbdev",
"used_by": null,
"vid": "0483"
If we look into the caf py code, we see that the "is_generic" attribute is set only if 'ID_MODEL' attributes contains the 'serial' string. In our case, 'ID_MODEL' are: FT232R_USB_UART or Dual_RS232-HS or RisingHF_LoRaWAN_Modem Either CAF has an updated version that is much more tolerant to detect serial device, either we need to patch it if possible. A good condition
would be to use "ID_TYPE" and check if it is 'generic'.
Code from here:
detail code of the detection function:
def discover_other_interfaces(self, ttydevices):
log.info('discover other interfaces()')
if not self.is_storage:
log.info('discover other interfaces(2), %s', self.device_path)
if not ttydevices:
return
log.info('discover other interfaces(3), with len: %s',
len(ttydevices))
if self.generic_params is None:
self.generic_params = dict()
usb_details = dict()
for usd in ttydevices:
log.debug('discover other interfaces(4), %s, %s, %s',
usd, self.device_path, usd.get('DEVPATH'))
log.debug('discover other (5), %s', usd.sys_path)
if self.device_path in usd.sys_path and 'serial' in
usd.get('ID_MODEL').lower():
self.is_generic = True
usb_details['device_path'] = usd.get('DEVPATH')
usb_details['device_name'] = usd.get('DEVNAME')
usb_details['vendor'] = usd.get('ID_VENDOR')
usb_details['model'] = usd.get('ID_MODEL')
self.generic_params = usb_details
self.device_name = usd.get('DEVNAME')
log.info('The device %s has serial interface. Updated
details..', self.device_path)
log.info('USB generic Parameters : %s',
str(self.generic_params))
return
show version:
#show version
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.7(3)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Mar-18 05:07 by prod_rel_team
ROM: Bootstrap program is IR800
Cisco829 uptime is 1 day, 3 hours, 10 minutes
System returned to ROM by CLI initiated reload at 10:28:56 UTC Tue Mar 26 2019
System image file is "flash:/ir800-universalk9-mz.SPA.157-3.M2"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IR829GW-LTE-GA-EK9 (revision 2.0) with 365568K/60416K bytes of memory.
Processor board ID FGL202123AQ
Last reset from CLI initiated reload
FPGA version: 2.7.0
BIOS: version 18 Production
BIOS: date[YYYY/MM/DD] :[2018/3/23]
MCU Bootloader : 28
MCU Application: 33
2 Serial(sync/async) interfaces
7 Gigabit Ethernet interfaces
9 terminal lines
2 Cellular interfaces
1 cisco Embedded AP (s)
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
976562K bytes of ATA System Flash (Read/Write)
250000K bytes of ATA Bootstrap Flash (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 IR829GW-LTE-GA-EK9 FGL202123AQ
Suite License Information for Module:'ir800'
Suite Suite Current Type Suite Next reboot
Technology Package License Information for Module:'ir800'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data datak9 Permanent datak9
Configuration register is 0x102
show iox host list detail
#show iox host list detail
IOX Server is running. Process ID: 330
Count of hosts registered: 1
Host registered:
IOX Server Address: FE80::2C8:8BFF:FE2F:11AC; Port: 22222
Link Local Address of Host: FE80::1FF:FE90:8B05
IPV4 Address of Host: 192.168.2.6
IPV6 Address of Host: fe80::1ff:fe90:8b05
Client Version: 0.4
Session ID: 1
OS Nodename: Cisco829-GOS-1
Host Hardware Vendor: Cisco Systems, Inc.
Host Hardware Version: 1.0
Host Card Type: not implemented
Host OS Version: 1.6.3.1
OS status: RUNNING
Interface Hardware Vendor: None
Interface Hardware Version: None
Interface Card Type: None
Services:
Service Name: Secure Storage Service
Service Status: RUNNING
Session ID: 2
Service Name: Host Device Management Service
Service Status: DISABLED
Session ID: 0
