Problem with iox firmware
CSCO12103188
Visitor
I just installed c800-universalk9_iox-mz.SPA.156-2.T.bin to support iox on my 819 4G router. Everything seems fine but I find some strange information in iox show commands, see under "Network Information" -> default gateway and mask:
show iox detail
IOx Infrastructure Summary:
Services State                 : OK
Networking Configured          : OK
IOS Network Reachable          : OK
Host Infrastructure State      : OK
System Information:
Build Date                     : Tue Jul 21 11:12:41 PDT 2015
Version                        : cwan_mizuno_dev/109
Uptime                         : 3d 8h 19m 45s
Disk Space Usage               : 32% (309MB)
Memory Usage                   : 38% (193MB)
CPU Utilization                : 1%
Networking Information:
IP Address                     : 10.10.98.2
IP Gateway                     : 255.255.255.0
IP Netmask                     : 10.10.98.1
IOx Host Agent:
Debug Level                    : WARNING
IOx Processes State:
caf                            : Running
crond                          : Running
ioxhad                         : Running
libvirtd                       : Running
monit                          : Running
I can reach the web-interface on 10.10.98.2 but when I try to run ioxclient commands towards it I get error 404. Running iox on ubuntu 14.04.
So I tried to upgrade my iox firmware to "p1021_c800.V1.0.0.20.bin.zip" but then I get this from my show commands:
show run | section iox
iox
host ip address 10.10.98.2 255.255.255.0
host ip default-gateway 10.10.98.1
host boot flash:p1021_c800.V1.0.0.20.bin
show iox detail
Services State                 : FAIL
Host Infrastructure State      : FAIL
System Information:
Build Date                     : Wed Feb 17 20:41:26 PST 2016
Version                        : cwan_mizuno_dev_v156_1_t_throt/57
Uptime                         : 0d 0h 4m 34s
Memory Usage                   : 40% (202MB)
CPU Utilization                : 2%
IOx Host Agent:
caf                            : Not Running
crond                          : Running
ioxhad                         : Running
libvirtd                       : Running
monit                          : Running
Anyone have any idea or experience about this behavior?
Thanks!
Oscar
6 Replies 6
tyu@cisco.com
Hi Oscar,
Looks like gateway and netmask are swapped in "show iox detail" output. I can reproduce this symptom in the lab. This is a display issue, network interface and routing table entry on IOx host are configured properly.
Could you try upgrading the IOS image to 156-1.T1? It is embedded with a newer version of IOx image.
Please remove "host boot flash:p1021_c800.V1.0.0.20.bin" from configuration before you reload the router.
-Ting
Where can I find 156-1.T1?
I only have access to the file area here on devnet community and the only image available here is the 156-2.T for 819 platform.
Oscar
Unfortunetly I don't have support contract for this device, I can only download images from the "restricted" section here on devnet. .../docs/DOC-68539.
And there you only have the "c800-universalk9_iox-mz.SPA.156-2.T.bin." version.
Could you add 15.6.1T1 to there?
Best regards
Oscar
Hi Steve,
I am also facing the same issue with the Iox. The gateway and netmask are swapped when I run 'sh iox detail' but the configuration seems to be normal.
I have booted the device with c800-universalk9_iox-mz.SPA.156-1.T1.bin image but unable to access Iox interface.
anyone have any idea about this behaviour?
Srikanth
Hi Ting,
Srikanth
