Showing results forĀ
Search instead forĀ
Did you mean:Ā
"Error while changing app state: Container doesn't seem to have a pid!?"
mardunca
Community Member
Hi all,
I'm trying to run a python script in a docker container on the IR829 and whenever I try to start the application I get this error:
$ioxclient application start main
Currently active profile :  default
Command Name: application-start
Saving current configuration
Could not complete your command :  Error. Server returned 500
"description": "Error while changing app state: Container doesn't seem to have a pid!?",
"errorcode": -1,
"message": "Error while changing app state"
Any ideas?
Thanks in advance!
6 Replies 6
mardunca
Community Member
Nevermind I fixed it by restarting the router, of course
rishit
Community Member
I have the same issue. Reboot did not fix it. App is written in java and works fine on local machine. Fails on the cisco router. Any suggestions?
What version of IOS/IOx are you using? You are recommended to upgraded to the latest version (15.7.M: ir800-universalk9_npe-bundle.SPA.157-3.M.bin).
Hi Steve,
Thank you for your prompt response.I am using the latest 15.7 version.
huntc
Community Member
I'm also seeing this. My S/W version as reported by the Local Manager is 1.5.1.5.
absure@cisco.com
I am also facing the below error
% Error: Error while starting the app: alpine, Cause: Container doesn't seem to have a pid!?
Did anyone have a fix for this ?
