Cybersecurity LabVM Worksation 20230210
Jueda
My VM keeps aborting in the oracle virtual box. Lab 4.2.7 of Cybersecurity essentials
@Jueda the Cybersecurity Essentials appears to be a Cisco NetaCad course, not one which is owned by DevNet nor linked to the DevNet sandbox. You would you need to contact NetaCad for this.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
6 Replies 6
Which lab / sandbox is this @Jueda ?
Cybersecurity essentials, Lab 4.2.7
Hope this helps.
ecorban
Hello. From the image attached this does not look like an virtual machine loaded in oracle virtualbox we provide in DevNet Sandbox. please forward on information to the support team or provide information on where you downloaded or aquired the vm so we maybe able to assist.
I downloaded the oracle Virtual box from this link https://www.virtualbox.org/ attached is the lab screenshot
csknmhmtefe
Hello, i have this problem too and i solved it. If you change the install directory of CyberOps Lab, default directory is (C:\Program Files\Oracle\VirtualBox or something) the problem is solved. My opinion is you will create a new folder on your desktop like "VM Base" and choose this directory for installation of Labs.
