Realtime capability of IOx app
bjarke.thormann
What realtime capability can I expect from an IOx app?
Would it be sensible to develop a soft-realtime control app (~100ms) using a Cisco 809 router?
Steve Zhang
Hi Bjarke,
I do not have the detailed performance data at hand, but it should be supported for 100ms (as I tried with one of my apps). You'd better test it with your own app. Hope it helps.
Steve
