Edge Computing Infrastructure
Labels
Like - is there an API call I can make against the CAF to get things like 829 SERIALNUMBER?For example:ioxclient platform infoHow could I get the same output into my IOX application?I can't seem to find solid CAF api documentation.  I know it must be...
Levi Iiams by Level 2
  • 13833 Views
  • 1 replies
  • 1 Helpful votes
Hi,I'm trying to lift a container on the IE4000 switch and it returns the following error:root@nuc:/home/nuc/Desktop/iox/lxctest# ioxclient app activate helloworldtestCurrently active profile :  IE4000Command Name: application-activateError. Server r...
We've been trying to use the Secure Storage Service on a flash-based IR829. We're using IOx 1.5.15. Unfortunately, we're unable to post objects successfully, now having read the documentation several times over.   Here's a sample session. First, we s...
huntc by Community Member
  • 17679 Views
  • 2 replies
  • 1 Helpful votes
Hello,we are currently running a pilot with 6 ir829 routers and have encountered 3 problems.We have an application that is running as a container on the router that gets sensor information and writes it on a usb stick and sends it to the cisco asset ...
tobias.hirt by Community Member
  • 4244 Views
  • 6 replies
When installing my LXC app on IOx I receive the following message:{ "description": "Invalid Archive file: [Errno 28] No space left on device", "errorcode": -1, "message": "Invalid Archive file"}This got me wondering whether old images are being retai...
  • 2684 Views
  • 2 replies
When uploading files into /data/appdata via the IOx Local Manager, I find that my app cannot read them due to privileges. I'm also unable to modify the privileges from within the LXC. Here are what the files look like from within the LXC:/ # ls -al d...
  • 1598 Views
  • 1 replies
Resolved! lxc fails
Hi there,I've been able to install/activate/start my LXC based application on IOx until recently. I was hoping that someone might point me in the direction of what to look at that could help me diagnose its issue. The app appears to start up and then...
  • 4672 Views
  • 4 replies
