%SYS-4-CONFIG_RESOLVE_FAILURE
nathan
Level 2
Level 2
Since this happened to me, I thought I should share this.
Messages like this appear constantly:
*Feb 11 09:34:24.861: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/network-confg) failed
This is explained here:
The user receives the %SYS-4-CONFIG_RESOLVE_FAILURE: error message in Catalyst switches that run Cisco IOS code | LAN, S…
And here:
https://learningnetwork.cisco.com/thread/19765
This default behaviour so long as there is no configuration in the system NVRAM. This can be turned off by configuring the device, or as follows:
  1. Press return a few time to get to the IOS prompt.
  2. Enter enable mode by entering "enable", followed by your enable secret, which you set when you configured IOS.
  3. Enter configuration mode entering "configure terminal".
  4. Enter "no service config".
  5. Enter "exit".
  6. Enter "write memory".
That should do it, and you should not see any more such messages and the new configuration will be written to memory. To check, you can use the "reload" command, which will reboot the device.
6 Replies 6
Alexander Stevenson
thank you
Gynsch
Community Member
Thanks a lot!
NetworkEngineering5185
Frequent Visitor
Frequent Visitor
AKA "no service config" should be the first line in the configuration applied, got it, thank you!
Ali-Mohammed
Frequent Visitor
Frequent Visitor
thanks it was helpful...
telestrial2020
Frequent Visitor
Frequent Visitor
Thank you. It was helpful.
voidpointer
Community Member
Still useful in 2026. Thank you!
