Using syslog UDP connection errors
David Owens
Level 2
Level 2
We recently implemented a syslog UDP delivery of several of our ESA logs to our security group for evaulation.  We are consistently getting this error message regarding these deliveries.  UDP should be basically be a blind connection - why would the IronPort reporting these errors?  Cisoc C670 ver 7.5.1-102 O/S
If this is expected behavior then what other options would you recommend?
Log Error: Subscription ISIS_MX_Mail_Logs: Network error while sending log data to syslog server 162.131.217.11 (162.131.217.11): [Errno 61] Connection refused
RSteveKadish
I have the same issue.  However, it's only a few alerts per day, and it does seem like the syslog messages are being recieved by the SIEM.  I'd also be interested in knowing what's behind the "connection refused" alerts.
