Anyconnect Popup when loss of network connection
Gilles Guillerm
With the Anyconnect client (mine is 4.9) on windows 10 laptop, when you lose the network, wifi for example, there is no network loss notification. Is it possible to bring up a popup to indicate this loss of network and how can I do ?
thanks,
Gilles
2 Accepted Solutions
Anyconnect uses the Windows 10 notification system, so they probably got turned off at some point.
Click on Start, start typing "Notification", and it should bring up the Notification & actions settings page.
Scroll down and find the Anyconnect settings and turn them on.
Yep... there's one other place that I forgot.
In the System Tray, right click on the Anyconnect icon. Click on "Show Connection Notices"
Notifications are enabled but no logout popup. when the network connection arrives, there is indeed Anyconnect which brings up a popup, but when disconnected, nothing....
The question was mainly about bringing up a popup when the VPN disconnected...
Gilles
