Can AMP kill and already running malicious process?
keitholsen
If AMP detects a malicious executable that's already running, will it kill the process, or can it only prevent new instances from starting?
Thanks!
Keith
csco12589127
Block malware in real time
AMP automatically detects and blocks threats in real time using global data analytics, machine learning, fuzzy fingerprinting, rootkit scanning, and a built-in antivirus engine.
From Cisco:Cisco Advanced Malware Protection (AMP) for Endpoints - Cisco
AMP scans continiously and blocks somehow if any found.
csco12589127
brmcmaho
The AMP for Endpoints connector is able to terminate processes if they are found to be malicious, yes.  Note the "Monitor Process Execution" setting under the File tab of your AMP policy settings.
sofian.said
Yes AMP will be able to kill the process
