Content Filtering Remote Users
cplatt1
What do you all do for content filtering on Remote iPads? I was going to set up Per App VPN with Chrome until I found out per app only supports Cisco AnyConnect, which cannot be used with MX Firewalls. So whats the best solution to limit their content (adult sites, etc) while these users are remote.
jared_f
Level 7
Level 7
@cplatt1 Assuming the devices are supervised you could push out the content filter configuration profile and set it to "Auto Filter"
(Systems Manager > Settings > Create New Profile > Restrictions > iOS Supervised)
Find this helpful? Click the kudos button. Thanks!
6 Replies 6
jared_f
Level 7
Level 7
Does that work with any browser or just Safari?
@cplatt1 I believe so, do you have a test iPad to scope it to? If not, let me know and I will do it.
NVM found the answer to that question it works on all thanks for the help!
Confirmed it works in Chrome.
