How to scan a file using CISCO AMP Endpoint connector using command line in Windows 10
hatim_johar
We are using CISCO AMP for Endpoints and wanted to know is there a way to scan a file using command line in Windows 10.
Troja007
Hello @hatim_johar,
starting an OnDemand Scan with Command Line is not availble. AMP provides a CLI (documented here), but managing ODSCans is not available.
As the AMP connector monitors endpoint activity and more, processes the data in the AMP backend, what you want to achieve?
Greetings,
Thorsten
Troja007
Hello @hatim_johar,
Greetings,
Thorsten
