3D7120 sensor GUI could not login
pt_wang
My customer Sourcefire 3D7120 sensor GUI admin could not login ( message : unable to authorize access) ,but ssh admin login OK.
Any suggestions?
Aastha Bhardwaj
Try logging in with admin username and password and see if that works.Otherwise you can reset the password.
Check link : http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/118631-technote-firesight-00.html
You also might need yo check the logs on command line and see whats the exact problem. YOu can view that under : /var/log/messages
Aastha Bhardwaj
Rate if that helps!!!
