FMC Deployment failed
stlourenco
Hi, Guys
I have the FMC Virtual Appliance in version 6.2.3 and the FTD in version 6.2.2 an ASA 5506-X with FTD image installed. Whenever I try to do deply in FMC I get this error message:
When I click on details, I have identified that there is a route-map that is applied in the inside interface to the PBR function. Follows logs:
Lina messages
FMC >> no strong-encryption-disable
FMC >> object network IP_SANDER
FMC >> host 179.108.169.67
FMC >> object-group service RDP tcp
FMC >> port-object eq 3389
FMC >> timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
FMC >> access-list CSM_FW_ACL_ line 11 remark rule-id 268435456: ACCESS POLICY: Giacomelli_Policy - Mandatory
FMC >> access-list CSM_FW_ACL_ line 12 remark rule-id 268435456: L7 RULE: RDP_SANDER
FMC >> access-list CSM_FW_ACL_ line 13 advanced permit tcp object IP_SANDER ifc inside object TS_T_3389 object-group RDP rule-id 268435456
FMC >> no user-identity default-domain LOCAL
FTD_GIACO >> info : INFO: Default-domain change will not impact existing configurations.
FMC >> no route-map PBR permit 10
FTD_GIACO >> error : ERROR: route-map PBR is attached to routing protocols
(EIGRP/RIP/OSPF/BGP/ISIS) or used in policy based routing.
Please remove the relevant configuration before removing the route_map
Other logs
Lina configuration application failure log:
Lina Files Rollback successful
Rollback APP was successful.
So I created a flex config that tries remove the route-map, as image below, but it doesn't worked:
And in the FMC there is a deploy pending with a lot modification. I'd like to know if there is a way to kill this deploy in FMC for e try again.
rmorenobb
I have the same issue, did you ever get a solution for this?
