FTDv in AWS
cbelcher
Just setting up my first instance of FTDv in AWS.  But for the life of me I can't figure out how to get the outside interface to reach the Internet.
I've got my Internet Gateway and all my other EC2 resources don't have any issues.   Looks like it's just a default gateway issue from the FTDv's perspective.  Any other EC2 you just point the 0.0.0.0/0 network to your Internet Gateway target.  Can seem to find a corollary in FTD?  Can't add a static route because AWS doesn't tell you the next hop for the IGW.
Any ideas guys? I must be missing something simple.
Cheers
ayo.okeowo
Hi there,
I ran into this issue just recently. To solve this, you'll need to assign an Elastic IP to the outside interface. Make sure your public subnet is in in the custom route table with a default gateway route entry. Then remove default route entry from your main route table where your private subnet resides.
