Snort Scripting
Hello
Is there a way to write custom SNORT rules (for IPS) and OpenAppID scripts(for a new Protocol or an APP) and use them in FTD or Firepower Services?
Links would be appreciated.
Raed Boshmaf
For custom snort rules you can check the following (The idea is the same, but the locations are a bit different, but mainly you would use the GUI provided editor or upload the custom rules into the FMC and enable them in your Intrusion rules) and syntax wise you can check any snort guide for further information.
http://www.labminutes.com/sec0175_asa_firepower_ips_custom_rule < version 5.X
https://www.youtube.com/watch?v=uN53tw_6bms < version 6.X
And for application detection, check these
https://www.cisco.com/c/en/us/td/docs/security/firepower/60/configuration/guide/fpmc-config-guide-v60/Application_Detection.html
http://www.labminutes.com/sec0169_asa_firepower_firepower_custom_application_detector_1
Hope the links help!
Raed Boshmaf
