unable to login in Firepower
John
How to reset the forgotten password in firepower?
Aastha Bhardwaj
Refer this : http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/118631-technote-firesight-00.html
Aastha Bhardwaj
Rate if that helps!!!
How about in sourcfire 3d system(sensor), how to reset the password, we have forgotten the password in gui even in cli.
The link which I have send you contains how to reset the password for CLI.
You would need to reboot the Sensor , and login with single mode and then change the password. Steps given in the link.
Aastha Bhardwaj
