ASA 5520 - Allowing Access to port 1433 from outside
mkatiwa
Hi guys,
Am trying to allow access from the internet to a web server in the DMZ hosting SQL server. I want to enable access through a public IP address. The application uses port 1433. I,ve set up the necessary ACL to allow any source IP and port to access the destination server.
Collin Clark
You're allowing everyone access to your SQL server? That's what we call an RGE. Require your partner/customer/whoever to VPN in.
Yes. VPN is definitely a better solution but my customer is insisting on this. How should I go about this. These are the steps I've taken so far:
x.x.x.x - Server public IP
y.y.y.y - Server private IP
Outside Interface
Create ACL applied inbound on outside interface to allow packets with any source ip/port and destination x.x.x.x port 1433
Create static NAT on outside interface to translate destination IP x.x.x.x:1433 to y.y.y.y:1433
Create ACL applied outbound on outside interface to allow packets with any source ip/port and destination y.y.y.y port 1433
DMZ Interface
Create ACL applied inbound to DMZ interface to allow packets with any source ip/port and destination IP y.y.y.y port 1433
Routing
A route to forward IP packets with destination y.y.y.y to the DMZ interface
I don't believe SQL uses 1433 as the source port. It should be using an ephemeral port. Also I don't think you need "Create ACL applied outbound on outside interface to allow packets with any source ip/port and destination y.y.y.y port 1433". If y.y.y.y is directly connected you also don't need the routing. Try changing your ACL to
access-list outside_in extended permit tcp any host y.y.y.y eq 1433
Then try a packet trace and see where it is failing.
packet-tracer input outside tcp 4.4.4.4 2383 x.x.x.x 1433 detail
Here is the drop reason:
Drop-reason: (sp-security-failed) Slowpath security checks failed
